I need some help in Land Development!!!!!!
Hi, I need to know how to do a grading in a terrain digital model with a 0.50m increment. I want to know if it is possible to put a first level and increase the next field 0.50m up from the first one.
God Bless you
God Bless you
RE: I need some help in Land Development!!!!!!
If that is the case there are various software packages that will do this. Perhaps you can elaborate a bit more about the model you have and what the aim or use will be?
If this assists try the topographical mapping module of ACAD. I personally use a package called MAPCAD in South Africa.
Let me know if you want more information?
Good Luck
I am also unsure of what you mean by 'grading.'
You said "I want to know if it is possible to put a first level and increase the next field 0.50m up from the first one." - Maybe you can access the data for the levels in a spreadsheet and just use an equation to add 0.5? (or have I misunderstood you completely?)
If you have the DTM data (x,y,z) in a .dat, .xls or .txt file then you can use them in a spreadsheet program (such as MS Excel or Lotus 123).
If you meant you wanted to contour the DTM at 0.5m intervals then I suggest you use Golden Software Surfer to grid the data - the software allows you to stipulate the parameters of the interpolation method and also all the x,y,z details.
I hope this is of some help to you.
Good luck
Dubliner
(DTM = digital terrain model)
Thanks!
And God Bless You!
Solangel
good luck
chip
