PRESSURE CHANGE IN VESSEL
A 5 Gallon Pressure Vessel(non-vented) is completely filled with Diesel Fuel #2.The vessel is pressurized to 500 psig, the temperature of the Diesel is 90 Degrees F. If the Diesel is heated to say 140 Degrees F, What is the equation to calculate the pressure rise?
RE: PRESSURE CHANGE IN VESSEL
I believe to solve this problem, you need a tabulation of the properties of Diesel Fuel #2 in the compressed liquid state. This is probably not something you can find in the run-of-the-mill undergraduate thermo text-book (mine only has tables for water in compressed liquid state). Someone in the Heat Transfer and Thermodynamics Engineering forum may be able to direct you to tables or an equation.
Good luck,
Haf
Best Regards
Morten
