Sheet Metal Conversion
I have a interesting question for the community.  I have been tasked with a side project, and am at a stopping point.  I am trying to create a globe of the earth to mount outside our plant, but am having difficulty.  I have created the sphere, then sketch planes, and finally, sliced the sphere into 8 pieces.  Now I am trying to flatten those pieces out to find a sheet metal blank size for them.  I will be cutting out the stainless steel sheet on our laser, and forming the parts with a english wheel, but am having difficulty trying to force solid works to convert the slice into sheet metal. I shelled out the sphere to .059 (16 ga stainless).  As a side note all the information on the outside of the globe will be laser etched.
RE: Sheet Metal Conversion
Check these two threads below
thread559-108630
thread559-12566
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
You will not be able to change the sections into Sheet Metal parts. To manufacture those parts in real life involves stretching & thinning (plastic deformation) of the material. SW (& most other solid medellers) cannot currently do that.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Not sure if this helps, or is what you need to do but what if you located a picture of the earth in a flattend (rolled out) view on the internet. Should have zig-zag cut outs on the top and bottom.  Then somehome re-create that pattern onto solidworks sheetmetal.  Now print out the sketch and cut it out with a knife or scissors. From there you should be able to tape it together or even use glue just to get a rough idea that it will work with sheetmetal.
Just a thought...
pj
I have actually done the paper model, i was hopeing to have it done in solid works.  It is not required of me to do so, but i was just trying to push the envelope.
WOW ... why so many sketch bends? Are you having to bump this in a Press Brake?
cheers
It will have to be of several parts. Create the model the way it will be made.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Actually no, we are going to use an english wheel to form it.
You only needed one Sketch Bend (at the widest point) with the bend angle set to 180deg & the bend radius set to 5.6875" to achieve what you had. A tiny flat at the sharp ends can be used to set the "Fixed Face".
cheers
Please let us know your findings.
cheers
I am SURE you can NOT flatten a sphere !!
It has been some 200 or perhaps even 300 years ago that some mathematician (Swedish ?? - though not sure) has proven this once and for all that you can NOT flatten a sphere
jacek0841 ... you are correct ... but you can (physically) create a spherical segment from a flat, however stretching & thinning of the material will occur.
SolidWorks cannot (at the moment) "handle" the plastic deformation calcs needed to create a flat from a sphere. The SurfaceWorks package from Aerohydro apparently can.
cheers
Here is a link for those unfamiliar with an English wheel.
http://hyperphysics.phy-astr.gsu.edu/nave-html/W02/globe.html
That piece is not what trekfan is asking about, but it is almost identical to one we produced at a previous job.  Flat patterns can be created for many shapes regardless of plastic deformation.  Just think of spiral chutes, square-to-rounds, and transitions.
http://img280.imageshack.us/my.php?image=smoothchute5ey.jpg
Flores
SW06 SP4.0
