Problem with Catia V4 Sessions
I am having trouble with catia sessions.
I can not change the active model in the session, has anyone had this problem before?
Thank you,
Thank you,
RE: Problem with Catia V4 Sessions
As in you cannot modify any geometry?
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Thank you..
Swap position ? toggle NO to YES.
Should do the job. You'll have to change the default method in the way your models are loaded.
