2 versions of SW & 2 Serial #'s?
Hi folks.
I have a small business on the side doing design and drafting work. I use SW2005 because that's what my clients use. I just got a new project but it requires SW2006. The client is going to let me use one of their licenses to do the job.
Am I going to have problems with having 2 versions of SW on the same machine; both versions running different serial numbers?
Thanks.
Casey
Thanks.
Casey
RE: 2 versions of SW & 2 Serial #'s?
Cyril Guichard
Mechanical Engineer Consultant
France
Kevin Carpenter
CAD Systems Specialist
Invacare Corp.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Casey
While you have use of the 2006 license, use it for all of your work. It will allow you to use 2005 and 2006. When the 2006 project is finished, just go back to your 2005 license.
Ben Loosli
Sr IS Technologist
L-3 Communications
As for getting issued a serial number, I will be using the nuber and license from my new client for 2006. Will it for sure be compatable with my copy of 2005?
I guess worst case would be to do all the 2006 and have to reinstall 2005 later. I should be able to get the 2006 stuff done without effecting schedule on the 2005 too badly. That's not the ideal solution, but I might have to swing it.
Casey
Casey
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Maybe it's time for a new (additional) computer? Perhaps it will pay for itself. Or, you can upgrade your own license of SW and simply use both 2005 and 2006 on your existing PC without the serial number conflict.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Others here may know better, but it might automatically use your current serial number. I have never had to enter the serial numbers on the sequential installs, but then again they all had the same serial number.
Flores
SW06 SP3.0
You could possibly create .reg files that would swap the serial numbers when needed
[HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Security]
"Serial Number"="[your serial number here]"
If you're not flipping between versions too much running a reg file to toggle this setting would be a solution. You may have to re-enter the appropriate REG code each time you switch...
