Extract Mass and CoG to Design Table
I have made config. spec. property definitions ending up with an Excel column header
$PRP@Weight
with text-value
"SW-Mass@@Default@hull.SLDPRT"
Acc. to SW-help I should now make a second column header containing "the standard design table information"!
What is the standard design table information header for these properties?
SW-Mass doesn't work.
Electronics designer getting started with SW03
