API Question for opening Excel
In my feable attempts to open Excel from SW, I have tried to mirror some previous code and it works to an extent.
This code was written from Excel to open SolidWorks. It opens SolidWorks and then a given document. Assume variables have been named and defined.
‘Opens SolidWorks
Set swApp = CreateObject("SldWorks.Application")
swApp.Visible = True
Set Part = swApp.ActiveDoc
‘ Load model and expand window
Set Part = swApp.OpenDoc("folder location\file.SLDPRT", 1)
Set Part = swApp.ActivateDoc("Pulley.SLDPRT")
swApp.ActiveDoc.ActiveView.FrameLeft = 0
swApp.ActiveDoc.ActiveView.FrameTop = 0
swApp.ActiveDoc.ActiveView.FrameState = 1
What I want to achieve is the same things, but from the reverse direction. I want to open Excel from SolidWorks.
Set ExSheet = CreateObject("Excel.Sheet")
ExSheet.Application.Visible = True
Set exDoc = ExSheet.ActiveDoc
' Load Excel and expand window
Set exDoc = ExSheet.OpenDoc("folder location\file.xls", 1)
Set exDoc = ExSheet.ActivateDoc("Pulley.SLDPRT")
ExSheet.ActiveDoc.ActiveView.FrameLeft = 0
ExSheet.ActiveDoc.ActiveView.FrameTop = 0
ExSheet.ActiveDoc.ActiveView.FrameState = 1
I’m getting lost at the point where Excel opens. It opens Excel and a sheet, but stops at the bold text line. The debugger message box opens and displays “Object doesn’t support this method or property”. I believe that I’m using the wrong syntax to keep going in Excel so I can’t even tell if the rest would be correct.
Any suggestions? My API experience is very basic. I’m a cutter and paster from examples and try to get them to work. So anything would help.
‘Opens SolidWorks
Christopher Zona - Senior CAD Designer
Concord, Ontario
RE: API Question for opening Excel
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Concord, Ontario
One cannot assume that API calls used in SolidWorks are the same as those for Excel.
I do not know exactly what object you are trying to retrieve. For the active workbook use xlApp.ActiveWorkbook, and for the active sheet use xlApp.ActiveSheet where xlApp is the excel application object. Your code looks like it returns the active sheet. Without looking into it more I do not know how to get the application object from your code.
SA
tblAnnot is a pointer to a BOM table (code to find the BOM on the sheet is not shown here).
The code reads the entire BOM into a 2D array then deposits the contents into the Excel sheet.
Hope this helps.
CODE
For i = 0 To tblAnnot.RowCount - 1
For j = 0 To tblAnnot.ColumnCount - 1
sTempArray(i, j) = tblAnnot.Text(i, j)
Next j
Next i
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlApp.Workbooks.Open ExcelTempPath
Set xlBook = xlApp.Workbooks(xlApp.Workbooks.Count)
Set xlsheet = xlBook.Worksheets(1)
For i = 1 To UBound(sTempArray, 1) 'skip the first line (headers)
For j = 0 To UBound(sTempArray, 2)
xlsheet.Cells(i + 1, j + 1) = sTempArray(i, j)
Next j
Next i
Thanks for the response. A combination of both samples worked for what I am trying to set up.
Concord, Ontario
