sandwich panel FEA
sandwich panel FEA
Does anyone know of a cheap, user friendly analysis program that will handle glass/foam sandwich strucutres?
I have the demo version of NASTRAN, which is great for truss-type structures, but won't let me create sndw. panels. Is this a limitation of the demo?
I am an amateur homebuilt designer, wanting to learn more.I would welcome correspondence with 'real' aeronautical engineers.
Peter Thomas, irondack@aol.com
RE: sandwich panel FEA
For example, you are probably looking to use the panels as floor boards. If this is the case you can analyse them for simple shear and bending using classical analysis techniques.
FEM of composite panels can be complex, and largely unneccessary in straight forward applications like home built aircraft.
If you need help with analysis, let me know.
Nigel Waterhouse
n_a_waterhouse@hotmail.com
A licensed aircraft mechanic and graduate engineer. Attended university in England and graduated in 1996. Currenty,living in British Columbia,Canada, working as a design engineer responsible for aircraft mods and STC's.
