coefficient of thermal expansion of AISI 415 steel (welding)
help please!!!!!
I try to simulate the welding of martensitic steel AISI 415 (stainless steel). I need the curves of the thermal expansion coefficient of this steel according to the temperature. I do not find these data nowhere. Can somebody say to me where I can find information about this steel or about a similar steel?
Thank’s in advance.
Barha
RE: coefficient of thermal expansion of AISI 415 steel (welding)
The values should be listed in ASME Boiler & Pressure Vessel Code, Section II, Part D.
Don't you mean 416?
You can find the mean CTE for three different temp. ranges
for the martensitic stainless steels 410, 414 and 416 at page 435 of ASM Handbook vol. 6.
They are:      Mean CTE from 0C to (x10 exp-6/K)
         UNS      100 C   315 C   538 C
410   S41000    9.9     11.4     11.6
414   S41400   10.4     11.0     12.1
416   S41600    9.9     11.0     11.6
Hoping this helps,
http://www.welding-advisers.com/
Thank you guys for your help but I forgot to mention you that I need the curves of variation of the thermal coefficient of expansion AT THE TIME OF WELDING. The values in the source that you gave me WELDER and the values that you gave me GOAHEAD Are valid only for a slow heating OR slow cooling.
At the time of welding, very high speeds of heating and cooling generate two curves (in hystereses) of this coefficient due to the phase transformation. So that, for the same temperature we’ve got two values of CTE according to whether we are in the heating or cooling phase. Those are the values that I need.
Israelkk, may be 416 also!!
Barha
