THIN INSULATION 3/5MM ONE SIDE SELF ADHESIVE
We are looking for thin insulation 3 to 5 mm one side self adhesive other side aluminium fold
Our idea is to stick in continu on flat sheet a such insulation and to profile after.
This is mainly for producing galvanised or precoated roof sheets for roofing metallic buildings
Let us know your possibility
RE: THIN INSULATION 3/5MM ONE SIDE SELF ADHESIVE
Hi Prodex:
may i know whats the requirement?
For instance, what temperature resistance do you require?
Our e-glass mat of 3mm & 6mm laminated with alum. foil might be able to assist you in this application.
There are also other materials which can be considered and I will be able to advise better if more information can be provided. Also, the qty. required and the location to shipped
cheers
