Higher DP than design in R/G centrifugal compressor
I'm running VRDS, VACUUM RESIDUE DESULFURIZING UNIT. And, as you guys know well, there is big and important centrifugal recycle gas compressor driven by high pressure steam. However, recently compressor shows higher DP than that of E.O.R condition presumably caused by high recycle gas molecular weight by high cracking effect in catalyst. My question is this, If we are operating with higher comp. DP than design, what parts of the compressor should be the main concerns and ?
You guys' in-depth comments would be appreciated.
RE: Higher DP than design in R/G centrifugal compressor
