Laser cutting help
Laser cutting help
I have just started work at a new company that has recently about six months ago purchased a new MAZAK HYPERGEAR 4 KW laser.
I have worked with two Mazak MKII machines A 2.5 KW and a 4 KW for around 4 years at my previous employer running lights out in an FMS cell.
The HYPERGEAR machine has had a bad history since the installation. The machine only has around 700 HRS on it and it has had the external optics replaced 4 times because of contamination problems. Mazak service is telling me that the external optics are only lasting around 1000 hrs on other installed machines?
Last week Mazak replaced the external optics and we are now getting around 3900 watts at the head. As the optics where contaminated again and we where only getting 1200 watts at the head. With the fresh set of mirrors I have no trouble cutting light gage HRS.
I can cut 0.250 HRS at 100 IPM at 4KW, 0.6KG oxygen, 500HZ, With a 7.5 IN convergence lens at -0.04 focus with a near glass like edge finish. When cutting 0.375 I can get the edge quality acceptable but only at a very slow feed “around 40 to 50 IN a minute at around 3kw.
(Question 1)
Does external optics replacement at 1000 hrs sound normal for a flying optics machine?
(Question 2)
If you have a flying optics machine “TRUMPF, BYSTRONIC, ETC” how long are your external optics lasting?
The MKII machines would go around 4000 hrs or more before optic or resonator service.
(Question 3)
I am trying to cut 0.75 HRS with good edge finish to reduce a machining step. I can get 0.750 to cut but with occasional thermal runaway. I suspect that the thermal runaway is material related as the material is just plain old A36 structural. Any advice as what to look for in thick plate that would attribute laser cutting problems would be helpful. Have you found a specific type of thick plate that cuts well on a laser. Any advise related to cutting A36 thick plate on a laser would be helpful.
(Question 1)
(Question 2)
(Question 3)
RE: Laser cutting help
I have always had the techs do the mirrors and mode adjustments. But I normally buy Convergence lenses and nozzles from IIVI or MATE Tooling. For the past 4 years I have been using chrome plated double nozzles for Mild steel on the MKIIs. They work great! You can get better feed rates and less freeze lines. They don’t work as good for cutting stainless or aluminum as you need way to high of a flow rate for that.
As for the Mazak HYPERGEAR I would not recommend this laser to anyone at this time. Most of the supposedly intelligent features don’t work that well. The torch changer and auto blue flame works fine but the nozzle changer works some times at best. The nozzle grinder is just a bad idea “A wire brush bolted to the table works much better”. The pallet shuttle needs something to stop debris from falling on top of a fresh sheet in the lower station. The double sheet detector needs to be able to read in inches and not only in metric. Last but not least the beam quality of the machine is poor. The feed rates for mild steel are around 40 to 50 percent faster on a fixed beam MK2 machine.
BK
I have noticed that the distortion gets globally worse as you start hitting the 3800 watt range.
The acrylic mode shot looks pretty jagged to me but the tech insisted on telling me that you will not get a mode shot as nice as the MKII off the HYPERGEAR?
But we are up and cutting now at least.
So, does the problem you are seeing vary not just with thickness of the material, but with lot??
BK
If you cut an "ugly" plate, see what the next one does.
If the problem seems to vary from plate to plate, then expose some plates to some mechanical / thermal excitation, which, combined with time (tuff to find in these days of JIT), so as to give the plates some chance of becoming less live. Putting them on or adjacent to a truck dock, and/or placing them outside on the west side of a building, so they are cool in the morning and stay in the shade during the AM, but then get smacked with the PM sunlight is one of my favorite methods. Cheap too!
You could also have a few pcs stress relieved (perhaps too-rich-for-the-room for production) and run those, to see if the problem is residual stress. You wouldn't believe how live raw plate stock, bar stock, tubing or pipe is, fresh from the mill.
BK
