COMPRESS and Fittings
Has anybody ever needed to have a Tee fitting as part of an ASME code vessel......say, a 16" dia. vertical vessel about 8' tall with a 16" Tee (branch out the horizontal axis)....???  If anyone is a COMPRESS guru, I can provide details...........
CW3
RE: COMPRESS and Fittings
Assuming a pipe coming out the shell then a tee attached and then 2 flanges. If this is the case then make the tee the same thickness as the pipe. This configuration you can't model in Compress, its just common sense.
