heat flux value - W/m^2 or W?
hi,
I am trying to apply heat flux to the surface of an element, would the unit of the value that I enter be
Watt/m^2 of just Watt...
I know heat flux unit definition is W/m^2, but doesnt the Watt applied be divided by the area that it is applied to?
thanx
Robin
RE: heat flux value - W/m^2 or W?
In Ansys heat fluxes are defined as being the heat rate per unit area.  So W/m^2 would be applicable in your case.  I've used other FE programs where a heat flux was simply a rate and independent of the area associated with that surface.
-Brian
