Need gland water flow rate formula/calculator
Anyone have an easy way to estimate the volume of gland flush water, based on shaft diameter, 5-6 rings of packing, assuming supply is 10psi above discharge pressure?
Any tips on explaining the correct gland settings to field personnel?
Thanks!
RE: Need gland water flow rate formula/calculator
sprintcar,
Talk with a vendor who sells similar gland packing. He may or may not have info from actual installations that will give you the information you require.....
Typically, in a process plant, "gland flushing water" is used like any other utility...... plenty is provided in a big system and system capacity is increased when they "run out"
Good Luck !!
MJC
OR.... how about the formulas for water flow thru an annulus?
