Can you recommend an Electrical Software Package?
Folks,
Our company is looking into getting a more intelligent electrical design software package than the one we are using. We’re trying to reduce the human error factors! Say we had to add an extra wire or relay to our motor control drawing, we might forget to number it, or have multiple wires with the same number, or the wrong supply to the device, or too many contacts off the relay etc. Would like some of your views on any packages you currently use or have used, pros and cons etc, really as much info as possible!
Thanks in advance.
Thanks in advance.
RE: Can you recommend an Electrical Software Package?
Once I had the drawing template set to the standard we used and the parts catalogue set I found it ok.
