Base plate + bolt (Easy request)
I am looking for a good design example of a bolted base plate using AISC.  Also, if anyone has recommendations on a spreadsheet for this design, it would be appreciated.
Many many thanks
paris
RE: Base plate + bolt (Easy request)
Assuming you are asking about a base plate with applied moment, a trustly reference is Omer Blodgett's classic, "Design of Welded Structures".  Also, AISC's Design Guide #1 is about column base plates.
Steel Structures: Design and Behanvior by Salmon and Johnson also has some good information for designing base plates.
I have a mathcad worksheet that does the calculations for a baseplate with axial load/moment by the method in Blodgett.  It is posted on my website:
http://home.mn.rr.com/gbbadger/index.html
feel free to download.
regards,
chichuck
