Unlock a Body in V5
Unlock a Body in V5
All bodies within the file seem to be locked : I cannot select any edge to perform a radius ... Do you know how to unlock ?
Many thanks
Many thanks
RE: Unlock a Body in V5
which workbench are you using?
could the body property of "pickable" been turned off?
That's my guess... Or could it be a non-editable entity?
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
Copy and Past the solid into another CATPArt and try again.
I finally found the way to solve ...
Using the body symbol from the tree, right click then go down in the menu to 'cancel property' (maybe not the right translation from french to english - 'supprimer propriétés' in french) ... and then I could access the solid again.
Strange anyway.
Thanks for all of your inputs
