m-file (level 2) s-function - dynamic frame data setting
I am now having problems when running my simulation with an m-file s-function that i have created. I recieve the following block error when i simulate:
Source 'registration/M-file (level-2)  S-Function' cannot have dynamic frame data setting for its output port 1. All sources should explicitly set all their output ports to be frame or non-frame
Here's my code (its pretty simple so i guess I'm missing somethimg):
function loadVTKpoints(block)
% Level-2 M file S-function for loading movie
% (image edge detection demonstration).
%   Copyright 1990-2004 The MathWorks, Inc.
%   $Revision: 1.1.6.1 $
  setup(block);
function setup(block)
  %% Register parameters
  block.NumDialogPrms = 1;
  block.DialogPrmsTunable = {'Tunable'};
  %% Register number of ports
  block.NumInputPorts  = 0;
  block.NumOutputPorts = 2;
  %% Setup functional port properties
  block.SetPreCompOutPortInfoToDynamic;
  block.OutputPort(1).DatatypeID   = 0; % double
  block.OutputPort(1).Complexity   = 'Real';
  %block.OutputPort(1).SamplingMode = 'Sample';
  block.OutputPort(2).DatatypeID   = 5; % uint32???
  block.OutputPort(2).Complexity   = 'Real';
  %block.OutputPort(2).SamplingMode = 'Sample';
  %ALSO HGOW WOULD I SET THE DIMENSIONS OF THE ARRAY IF IT IS RETRIEVED
  %WITHIN MY FUNCTION
  %block.OutputPort(1).Dimensions = size(points);
  block.OutputPort(1).Dimensions = -1;
  block.OutputPort(2).Dimensions = 1;
  %% Register methods
  %%IVE TRIED BOTH OUTPUT AND OUTPUTNONFRAME
  block.RegBlockMethod('Outputs', @OutputNonFrame);
  %block.RegBlockMethod('Outputs',                 @Output);
%endfunction
function OutputNonFrame(block)
    CT_input_directory  = block.DialogPrm(1).Data;
    vtk_file        =   textread(CT_input_directory,'%s','delimiter','=" ','whitespace','');
    points_num      =   str2double(vtk_file(12));                                                       %Number of points
    points_end      =   14-1+3*points_num;
    index=0;
    index   = (14:points_end);
    points  =  str2double(vtk_file(index));
    clear vtk_file;
    block.OutputPort(1).Data = points;
    block.OutputPort(2).Data = cast(size(points),'int32');
%endfunction
