Drawing Property Plat
I am trying to create a CAD drawing of my property to use to design a sprinkler system. I can't figure out how to create the property lines using angles and distances in survey foremat. Any help would be appreciated. Using CAD 2005.
RE: Drawing Property Plat
example
n24d38'23"e
cadnutcase
This has always aggravted me that you couldn't enter units that you didn't have set.
For your example to input nbarings/distances:
Command: l LINE Specify first point: [pick or enter point]
Specify next point or [Undo]: @45.34<n23d45'33"e
Was reffering more to the feet and inches when you are in decimal. At least in Acad 2000.
I always work unitless distances; so if you prefer " or ' or mm or ligthyears or whatever, you'll have to add the suffix.
MULTIPLE
Enter command name to repeat: PLINE
Specify start point: 0,0,0
@132.37<n39d16’0”w
@50.13<n32d45’0”e
@148.41<n45d39’0”w
@163.25<n37d21’40”e
@318.51<s49d56’30”e
@249.81<s46d7’0”w
Remember, amateurs built the ark...professionals built the Titanic. -Steve
You can use the LINE or PLINE command. No need to precede command with "multiple" though, as the command will prompt for successive points until you hit "enter".
