Valve locations in diaphragm pump
Why are a diaphragm pump’s inlet and outlet reed valves located away from the center of the diaphragm? I would think that the pump would be more efficient if the valves were near the center, where diaphragm deflection is largest. Do you know of any relevant studies?
