Halogen-free FR4 and RoHS
Hi Eng-Tipsors,
This is my first question. I did a few searches that came up empty, so please forgive me if this is redundant.
I need to get RoHS compliant PCBs. My supplier has a "halogen-free" option that costs a little more, and is not available for all my boards.
RoHS bans Polybrominated biphenyls – PBB and Polybrominated diphenyl ethers - PBDE. And bromine is in the halogens.
So the question is: does anybody know what the halogen in FR4 is?
Thanks.
e2zn
Thanks.
e2zn
RE: Halogen-free FR4 and RoHS
TTFN
I have chosen to specify material from outfits that appear more professional and will re-address the issue later after the confusion has settled down. This means for the short term I will pay higher prices and suffer longer leadtimes.
Also, for a long time, FR4 has been a commodity product with the business going to the lowest cost source. Now that RoHS is coming, laminate vendors are charging higher prices and longer lead times - if desired laminate is even available at all!
The following is a list of some of the major laminate vendors. Check through these to see which meets your needs.
Isola Polyclad Park/Nelco ITEQ Nanya
Your PCB manufacturer should be able to get quite detailed reports using ICP testing (often through SGS Labs).
Do you know the laminate manufacturer? I may have details on their laminates.
Thanks to you all for the input.
IRstuff, you prompted me to begin a number of translation-challenging communications with our offshore supplier that solved the immediate problem.
In addition to that, Comcokid and Dancey, your insight also proved valuable in getting me more experience with specifying these materials.
Since we are always re-quoting jobs to reduce cost (comsumer equipment) I now feel that I can take care of our future needs.
So at the end of this process I seem to have discovered this:
Although you would think that specifying "RoHS compliant" should be enough to get same, you really need to double check!
DIY wins again!
Thanks to you all for taking the time to help.
e2zn
