Partial Drawing View
I have a partial section view in a drawing that I would like to make a projection view. (no section) I am not able to modify the section sketch to be outside of the part geometry. Any suggestions?
Thanks.
Thanks.
RE: Partial Drawing View
Are you getting an error message?
How are you trying to place the view?
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Why are you trying to move the section line?
The section line is probably constrained in some way to the parts geometry. Click the line and end points (seperately) to see the constraints.
Not sure if this will work anyway - I've never tried it. Is it possible to actually get a view with the section line outside the part?
I would have expected the "section" view to crap out if the section line didn't intersect the model. Probably because I used I-DEAS for a number of years and that's most definitely what happened in such a situation.
