Invalid Floating Point Error?
When trying to print an entire report I get this error.
I can print one node at the time, but not all.
??  Any thoughts
RE: Invalid Floating Point Error?
This can occur with version 7.1 if you try to print or view a tabular storage or discharge table for an undescribed node.  To avoid this, make sure all the nodes are described, or don't select the tabular storage or discharge tables.  (All graphs and hydrograph tables are fine.)
Note: Full details on any software problems (including this one) are available by selecting Help | Check-for-Update on the HydrocAD manin menu.
Thank you!
