GRP Pipe fittings
GRP Pipe fittings
GRP Pipe fittings
Dear Friends,
can anybody know any website from where i can have GRP pipe fittings deimensions and weights (specially).
i am able to get GRP pipe fitting dimenions from FLOWTITE catalog (limited to only flanges, tees and elbows)....but could not able to find weights of the fittings..
Any help will be appreciated...
RE: GRP Pipe fittings
Hi friends,
thaks for your comments......
the pipingdesigner link was excellent...
so, pipingdesigner i have one question now...the link u give me has frp fiitings dimenions.. can i use it for GRP tooo..... if so why?.... since FRP and GRP ocmpletely two separate things...
I believe there are a great many acronyms that for whatever reasons that have sometimes been applied to variously reinforced (I think most often with some form of fiber or glass) polymeric or filled polymeric or plastic walled pipes or fittings, including the couple you note.  For a larger list of these acronyms you could probably look in standards such as AWWA C950 etc.  As far as weights of fittings for such systems, while there may not be a huge difference in density of whatever differently manufactured types of wall there are, you would probably be best served to consult with the fabricator of the actual fittings you will be buying as there could be some more variation than pipes in thicknesses and other dimensions etc. in these due to actual configurations and dimensions they choose to make to satisfy conditions.
