Flanges Max Allowable Pressure
My customer has specified some coils for an heat exchanger to be designed at 153.1 barg & 100°C with flanges 900#.
I already bought the flanges and I then realized that for 900# at 100°C the max allowable pressure is well below 153.1 barg, i.e. approx 139 barg!
I checked the worst operating conditions at one of the nozzles, which are 57°C & 147 barg, which are acceptable for 900# flanges.
My question is: can I keep the flanges?
RE: Flanges Max Allowable Pressure
See other post.  Start negotiating the exchange.
Its only acceptable if you're customer derates his design conditions. Flange selection is based on design not operating conditions.
Scesare:
Another solution is to perform a calculation of your flanges for 153barg@100°C. If they are adequate dimensioned you are allowed to use them for the specified pressure.
Sorry, I mean 153.1 instead of 153 barg
www.OneTB.com
