Drafting symbol
Drafting symbol
Drafting symbol
I have a drawing that has a triangle with an "S" inside of it located to the left of a parallel datum callout. Can someone define this for me?
RE: Drafting symbol
rofl
From SuperASME-y14.5
Seriously, I'm not sure what the symbol means.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Drafting symbol
Triangles are 'usually' used for revisions. Could the revision be that high for your drawing?
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Drafting symbol
Well, if it is a revision, there should be a revision history block somewhere on the print.  And then we all laugh "Rev S?!?!  Rookie."
RE: Drafting symbol
In the automotive industry, a triangle would mean a "signifcant characteristic" but it does depend upon the Customer.
In GD & T using the older standard, it does mean "regardless of feature size" but I don't think that it applies here.
Looks like a Customer phone call is coming up.
Good luck!
DD
RE: Drafting symbol
The SW symbol for "regardless of feature size" is an 'S' in a circle ... if I remember correctly.
cheers
RE: Drafting symbol
Maybe the drafts'person' (you can never be sure these days), mistook the number 5 for the letter S....
In that case, the revision would be the 5th one.
I see it quite often in other things, but never before in a revision triangle.  That's pretty standard.
______________________________________________________________________________
This is normally the space where people post something insightful.
RE: Drafting symbol
If the drafter knew about standards, he/she should know that "S" is not used as a rev, for that reason of mistaken as a 5.
Chris
AutoCAD 06
FAQ559-1100
FAQ559-716
RE: Drafting symbol
A guess here... could it be a statistical measurement?
RE: Drafting symbol
Hello all,
I think is a special note regarding to this dimension or datum.
ASME Standars using it as a square whith a number inside & connecting whith a specific Note.
May be this is a variant way.
An example will be:
dimension =  "(square with 1)" 6 -/+ 0.3
and at general notes section will be says:
1. This dimension applys before be bended (then this is now an "especific note")
Sorry for my english jeje
Saludos desde Mexico
RE: Drafting symbol
XZWHHL,
If you have no company specific standards governing a non-ASME-Y14 symbol, then consider revising the symbol to current standards to clarify it's meaning....no todo lo que es escrito es ley.
Which part of Mexico....Puebla?
RE: Drafting symbol
I do believe it is some sort of critaeria to highlight key characteristics (kinda like KPCs and KCCs).
I am almost sure I saw some of these on drawings. I'll look at that
Cyril Guichard
Mechanical Engineer Consultant
France
RE: Drafting symbol
This  triangle with S inside mean a Safety Weld.
Please, if you have any cuestion let me know,
Iam Luis E. Peña, from Mexico
RE: Drafting symbol
Quote (ewh):
I've seen "S" in a diamond used for this purpose, but not a triangle.
RE: Drafting symbol
LuisenP,
Is that a standard symbol or a "commonly used" one?  Is it possible to provide a reference for those interested?
Tks
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
RE: Drafting symbol
We use triangles to designate flag notes.
