Properties of combined fluids?
I am looking at a waste stream composed of NaCl, water, and HCl. I know the mass flow rates of each component, but I am looking for physical properties (i.e. viscosity) of the stream as a whole. Any ideas for this ME? Thanks.
RE: Properties of combined fluids?
For the blend, I would assume the effects are independent of each other.
Water viscosity can be found from a good steam table. A good online one is at NIST, at http://webbook.nist.gov/chemistry/fluid/
Good luck,
Latexman
