how to project ft&a views to a 2D drawing?
Hi.
Using v5r15.
I have several views created using FT&A at the part level. Is there a way to project those views to a 2D catdrawing?
Mike
Using v5r15.
Mike
RE: how to project ft&a views to a 2D drawing?
Hope that helps.
Tools->Options->Mechanical Design->Drafting under the view tab, if you scroll it to the bottom you will find a setting that coud be very helpful, View from 3D. If you toggle on "Keep layout and dressup...." it will allow you to independently from the 3D view to position (and change fonts) the FT&A/Annotations on the drawing.
