rolling without slip
Can somebody give me a link, or a tutorial to learn how to make a cylinder roll without slip on a giant box. (I just search how to do : joint gear, wheel and tire ..).
We have already tried out what could work, but there is always errors in simulation. That's why we are looking for the right way to do it.
Ps: We are french students and beginners with msc adams view, so please be very complete and simple in your answers.
Thanks a lot.
RE: rolling without slip
A GCON is the easiest/most generic way to implement this.
Jesper Slattengren
www.prattmiller.com
I set up a simple roller dropping on to an inclined block.
Worked first time.
Here's the contact statement
!                          adams_view_name='CONTACT_1'
CONTACT/1, IGEOM = 2, JGEOM = 1, IMPACT, STIFFNESS = 1.0E+005, DAMPING = 10
, DMAX = 0.1, EXPONENT = 2.2, COULOMB_FRICTION = ON, MU_STATIC = 0.3
, MU_DYNAMIC = 0.1, STICTION_TRANSITION_VELOCITY = 100
, FRICTION_TRANSITION_VELOCITY = 1000
The roller hits the ramp, bounces, and then rolls down the ramp.
here's the entire adm
ADAMS/View model name: model_1
!-------------------------------- SYSTEM UNITS ---------------------------------
UNITS/FORCE = NEWTON, MASS = KILOGRAM, LENGTH = MILLIMETER, TIME = SECOND
!----------------------------------- PARTS -------------------------------------
!----------------------------------- Ground ------------------------------------
!                            adams_view_name='ground'
PART/1, GROUND
!                           adams_view_name='MARKER_9'
MARKER/9, PART = 1, QP = -150, -300, 0
!------------------------------------ Part -------------------------------------
!                            adams_view_name='PART_2'
PART/2, REULER = 30D, 0D, 0D, MASS = 608.478, CM = 5, IP = 2.953653623E+007
, 2.598708125E+007, 1.267662498E+007
!                           adams_view_name='MARKER_1'
MARKER/1, PART = 2, QP = -300, 50, 0
!                              adams_view_name='cm'
MARKER/5, PART = 2, QP = 25, -100, 200, REULER = 90D, 90.00000016D, 359.9999998D
!                           adams_view_name='MARKER_8'
MARKER/8, PART = 2, QP = -279.9038106, -184.8076211, 0, REULER = 330D, 0D, 0D
!                            adams_view_name='BOX_1'
GRAPHICS/1, BOX, CORNER = 1, X = 650, Y = -300, Z = 400
!                            adams_view_name='PART_3'
PART/3, QG = 0, 110, 960, REULER = 90D, 90D, 270D, MASS = 10.33912869, CM = 7
, IP = 81178.31507, 81178.31507, 7269.699857
!                           adams_view_name='MARKER_6'
MARKER/6, PART = 3, QP = 600, 150, 0, REULER = 90D, 90D, 0D
MARKER/7, PART = 3, QP = 750, 150, 0, REULER = 90D, 90D, 0D
!                          adams_view_name='CYLINDER_2'
GRAPHICS/2, CYLINDER, CM = 6, LENGTH = 300, RADIUS = 37.5
!---------------------------------- CONTACTS -----------------------------------
!------------------------------ DYNAMIC GRAPHICS -------------------------------
!-------------------------------- CONSTRAINTS ----------------------------------
!                           adams_view_name='JOINT_1'
JOINT/1, FIXED, I = 8, J = 9
!------------------------- GRAVITATIONAL ACCELERATION --------------------------
ACCGRAV/JGRAV = -9806.65
!----------------------------- ANALYSIS SETTINGS -------------------------------
OUTPUT/REQSAVE, GRSAVE
RESULTS/XRF
END
Cheers
Greg Locock
However, I agree with jslat, if you cannot have any slip then you'll have to set up a gear coupler. That's covered in the tutorials.
Cheers
Greg Locock
Actually, a GCON is more generic than the coupler. And way cooler. But it needs the C++solver.
Here is a small testmodel (that I already posted on the MSC forum):
UNITS/
, FORCE = NEWTON
, MASS = KILOGRAM
, TIME = SECOND
PART/1
, GROUND
MARKER/1
, PART = 1
, QP = -550, 0, 0
GRAPHICS/1
, BOX
, CORNER = 1
, X = 1150
, Y = -250
, Z = 500
PART/2
, MASS = 24.50756429
, CM = 3
, IP = 1.225378215E+005, 81691.88097, 81691.88097
, VX = 50
!                           adams_view_name='MARKER_2'
MARKER/2
, PART = 2
, QP = 0, 100, 0
MARKER/3
, PART = 2
, QP = 0, 100, 50
, REULER = 270D, 90D, 90D
GRAPHICS/2
, CYLINDER
, CM = 2
, LENGTH = 100
, RADIUS = 100
!                            adams_view_name='GCON_1'
GCON/1
, I = 3
, FUNCTION = DY(3, 1, 1)-100
!                            adams_view_name='GCON_2'
GCON/2
, I = 3
, FUNCTION = VX(3, 1, 1)+100*WZ(3, 1, 1)
ACCGRAV/
, JGRAV = -9806.65
OUTPUT/
, REQSAVE
, GRSAVE
RESULTS/
, XRF
END
Jesper Slattengren
www.prattmiller.com
