Error occured in Electromagnetic/Thermal Analysis
Hello, Everyone!
 I tried RF/Thermal analysis for RF cavity of Particle Accelerator.
 Firstly I chose HF119 elements and performed HF electromagnetic solving. I set boundary conditions of cavity wall as electric wall and also applied surface impedance.
 Next, I meshed all cavity surface areas with SURF152 element and input some macro to apply the heat fluxes on the element. So the heat fluxes were applied to the nodes of SURF152 elements that match node-for-node the mesh on the surface of the RF model (with HF119 elements).
 Before next step, I clear RF mesh and delete the associated volume only (not area). Duplicating existing areas meshed with SURF152 I built the thermal solid model of the cavity shell volume with the SOLID87 element.  Merging keypoints to attach the area containing the heat flux elements and I meshed the model with SOLID87 elements. Applying thermal boundary condition I solved with the BC and heat fulx previously set.
 If the analysis is solved successively I may look temperature distribution in the cavity shell volumes. But An error occured and analysis was stopped. The error is appeared on solving thermal analysis.
"All nodes on the exterior faces of PML region with ESYS 0 have PEC
 boundary condition.  Please check the mesh density."
I cannot understand why the error occured? I just tried to solve thermal analysis but the error is about electromagnetic boundary conditions.
Can Anybody explain why this error occured and how I can fix it?
