Inflatable plugs for pipe isolations
I need to isolate a gas main so we can enter a pressure vessel for cleaning. The gas is blast furnace gas at atmospheric pressure and approx 40deg Celsius. There is no position for a slip plate, but I have heard of inflatable balloons being used to isolate a main temporarily. The main I need to block is about 4 metres in diamter. Does anyone have any experience with these plugs? Do you know if they can be used on a main of this size?
Luke
RE: Inflatable plugs for pipe isolations
Here is a site with about every type imaginable.
The last time I check an inflatable plug or in fact any plug wasn't allowed for vessel entry.  Make sure you check with the jurisdictional authority.
http://www.cob-industries.com/pipeplugs.htm
