SE v18 IntelliMotion AVI export problem
I have an assy I'm putting motion to. Revolution joint and a translation joint.  I can get the simulation to run ok, but when I try to export an AVI file of the animation I get an error and get kicked out.  I have contacted UGS and sent in the required files to get a solution. When talking to a rep we went through a few things and nothing worked.
Anyone else having a problem with this? Or find a solution?
Jeff
RE: SE v18 IntelliMotion AVI export problem
Hi
Which version of SE and which update are you using ?
I would update the driver for the graphics card. Which card do you have by the way ?
What happens if you hide someparts or try without the VHL ?
Fred
