What consumables would you use on API5L X52?
The Material is API5L X52.What consumables shall I use. I think I can use PZ6500 and Murex Ferex 7016. The pipe will be getting heat treatment . Any know what temperature it will be stressrelieved at.
RE: What consumables would you use on API5L X52?
htt
PS; you can look up the WPS that applies to API 5L X52
I think you have misunderstood stanweld's post.
He mentioned E6010 and E7010 for cross country pipelines, which means that the weld bead comprises of E6010 in root and E7010 for hot, filling and capping.
IMHO, the reason for using E6010 in root pass is its excellent penetration in scenerios of poor joint fit up which are frequently encountered when laying cross country pipelines. Using high strength electrodes in root bead is not recommended because it does not give that much penetration and may cause cracking in root bead when a heavy walled pipe is settled on wood supports after completion of root pass.
Owais
