Sketch on flat-pattern & file version numbers??
Can I not sketch a curve on a flat pattern using the [flat pattern] command? When I do it re-bends the part when it takes me into the sketcher. In the past I've always just used [Unbend - All] and that allows me to sketch on the "flat pattern". I guess it's no big deal. I can continue to [Unbend].
Also, is there something I need to change in the config.pro to be able to see version numbers on created files? Without having Pro/Intralink those versioned files can get out of hand after a while, but the way it is right now there is no version number, so I have to go by date to figure out the most recent version...
thanks...
thanks...
RE: Sketch on flat-pattern & file version numbers??
display_full_object_path yes
-Hora
<tg>
BTW, I had to go into the computers folder options and turn off [Hide extesnsion for known file types] in addition to display_full_object_path yes...
-Hora
