PID loop - long residence time
Hi there,
I am trying to control a mass flowmeter to input Chemical A into a series of reactors, each with a residence time of 30 mins. I need to dope enough of Chemical A to remove environmentally harmful Chemical B from the reactors (need <1ppm). My analysis sampling point for Chemical B is after Reactor 2, so total residence time is 1 hr (after 2 reactors x 30 mins each).
I am using a PID controller to control the flow of Chemical A into Reactor 1 based on the ppm level of Chemical B out of Reactor 2. It takes approximately 10 mins to get a ppm reading of Chemical B via the online analyzer.
Once I get a ppm reading for Chemical B, I set the flowrate for Chemical A dosing. The problem is that if I change the flow of Chemical A, I do not see the effect of this change (lowered ppm reading of Chemical B) for at least 1 hr.
My knowledge of controllers is very limited; I realize that this problem may be very basic and so I appreciate any help/ideas I can get!
Thanks in advance!
Thanks in advance!
RE: PID loop - long residence time
As JLseagull states, a Smith Predictor is a classic way to deal with delays
(see http://www
The model of the "Plant" has to be pretty good though for the Smith Predictor to work well as pointed out in the above article.
If so add some feed forward to the loop so the flow of A is changed before the analyser sees the result.
The PID can then fine tune.
In my world this is known as cascade control. I have not heard of Smith Predictor before, but I will be sure to school myself on that topic immediately. May be similar.
Go Google feedforward cascade
m777182
m777182
http
Good luck,
PS. From practice I know deadtime like these (distance/velocity-lags) are very difficult to control.
A by-pass line, by-passing the big tanks, directly inserting into the reaction tank should be considered.
Keith Cress
