What is "turndown ratio" ?
I understand that it's the range of flow ? for example max flowrate (100%open) = 25 ft3/min and has turndown ratio = 150:1 .It means the accurate minimum flow of this valve = 25/150 = 0.167 ft3/min, right ?
Nong
Nong
RE: What is "turndown ratio" ?
maximum controllable flow
Rangeability R=-------------------------------
minimum controllable flow
normal maximum flow
Turndown ratio T=----------------------------------
Genrellay valves are designed so that T=0.7*R where R is between 20 and 50.
Best Regards
Morten
You can actually not say much based on your numbers above, because the flow when the valve is 100% open is NOT controllable and you can therefore not calculate your minimum controllable flowrate.
Best Regards
Morten
Thank you, but I'm quite not clear from your answer, you mean T = 14 to 35 or 2.5:1 ? (because I always see that turndown = Numbers : Numbers
Rdgs,
nong
My second positing simply tells you a connection between R and T. But this connection is emperical and not true for all valves.
Best Regards
Morten
Mostly turn down ratio will indicate the flow parameters . but it is not a neccesity sometime pressure could be a critical turn dowm parameter for which we would be asked to give the gaurantee .
regards
kumar
kum@epc.ltindia.com
If Max flow is 100 GPM and Min FLow is 10 GPM
Turndown is 10:1 (100/10)
Some times turndown is incorrectly applied to valves, which is actually rangeability.
Rangeability is the range overwhich the valve can control - Ratio between the maximum and minimum flow coefficients. So if a valve provides good control between 2% and 98% of the flow capacity the rangeability is 49:1 (98/2).
Naturally this is a simple explaination and there can be other factors that may affect the outcomes, such as pressures.
But in general, these definitions should get you started.
Perry's disagree with you. What you have stated is what they term "rangeability" whereas turndown (as i previously posted) is defined as:
Normal max. flow
T= ---------------------------
min. controllable flow
and
Max. controllable flow
R= _____________________________
Note that "normal max flow" is not the same as "max. controllable flow". Anyway since this post is more than 1 month old we better hope Nong already got it sorted out
Best Regards
Morten
I have gone by those definitions for years, although I know that they were often used interchangably. But I checked the ISA standards this AM and it seems that I was wrong, "turndown"is obsoleted and rangability is stated as you say.
Thanks for the heads up.
