Quantity of Part in an assembly on the Part Drawing
5
I know round about ways of doing this but I am wondering if anyone out there has there own nice easy method and if they wouldn't mind sharing it.
Lets say I have a panel part that appears in a machine assembly. The assembly can dynamically change which will automatically change the quantities of the 'panel' part which are in the assembly.
I would like the panel parts drawing to now state how many times the panel is used in the assembly (in the same was as the Assembly BOM will give this info).
Anyone know a good way of doing this?
RE: Quantity of Part in an assembly on the Part Drawing
I think this means you cannot use common panels on other assemblies. Is this true, that you will never use the same panel on two different assemblies?
Bradley
Seems like configurations of the assy will work.
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 06
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Yes this can be done and it can be done parametrically.
  • In your part drawing, insert a view of the assembly and position the view outside the drawing sheet
  • Add a balloon to the part and choose "Quantity" for the balloon text
  • Change the balloon style to "No Leader"
  • Move the balloon onto the desired location on the drawing sheet
Now you have the assembly quantity on your part drawing and it will update with changes to the assembly.  This will obviously increase the size of your part drawings but it is the easiest way to achieve this goal.
Bradley - The Panel will be particular to each assembly and will not be used in any other assembly.
ctopher - I'm not sure I understand what you mean. I need the qty of parts which appear in the assembly on the part drawing.
Stoker - What you suggest will work but my assemblies can be really big which will mean sluggish speed opening the drawings. I suppose I would use a configuration of the assembly with everything suppressed except the panel and hide that view. (heh - maybe that is what ctopher means)
Thanks for the replies.
4
Neil,
From your initial post, it sounds like panel quantity is driven by a pattern/equation.  This may be one of those "roundabout ways", but you can:
1. Create a sketch in the assembly consisting of one construction line with a length dimension.
2. Make an equation such that [line dimension]=[pattern qty]*1.  You have to go through an equation rather than link values because you can't link values on two different dim types.
3. Create an in-context sketch on the part, also consisting of one construction line.  Make the endpoints coincident with the endpoints of the assembly sketch.
4. On the part drawing, show the sketch, add a ref dim for the line length, and create your note with a link to that ref dim.  You can then hide the sketch and the ref dim created.
[handleman[/b] ... great solution. thumbsup2
You should turn that into an FAQ for future easy reference. That question has been asked before & will probably be asked again.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Handleman - That is a clever way around the problem. Have a star!
