powder coatings
powder coatings
I am reading more and more these days on powder coatings .The doubt which I have is whether application in the traditional manner ie,spraying the coating over the substrate in a liquid form is inferior in terms of physical and chemical properties with respect to a coating applied using the powder coating technique assuming both are having the same resin base ??
Any input is welcome .
Best Regards,
NIk Smith
Best Regards,
NIk Smith
RE: powder coatings
RE: powder coatings
Cory
RE: powder coatings
Yes I have a specific question .Can this process of powder coating be used for coating hot glass ( at 700-800 degC) ? I have tried coating glass at the above said temperature but with the iquid based coating the glass cooled too rapidly and the powder did not adhere well nor was it possible to apply it to a thickness as to have an opaque coating .
best regards,
NIk Smith
RE: powder coatings
