Condensation of steam in tanks with cold inlet flows
What is a good way of calculating the rate of condensation of steam in a tank due to a cold inlet flow of water, through a nozzle in the roof?
The water falls up to 8m to the floor of the tank. There is no spray nozzle, just the open pipe.
This is a sealed tank at atmospheric pressure. The rate of condensation affects vacuum protection.
