flow regulating in the vacuum system
What's the flow ragulator for vacuum? My system is
Particle source -> filter -> valve -> vacuum pump.
The flow rate is about 1 acfm. While the particulate is captured by filter, the pressure drop is increased. To maintain the flow rate, the valve should be opened gradually. Is there a type of regulator that I can use between filter and vacuum pump?
The particles are less than 1 miron coal ash, actually, the purpose of this system is collecting the particles for other experiment. The valve or pressure regulator should locate after filter.
Thanks in advance
Thanks in advance
RE: flow regulating in the vacuum system
How about:
Particle source -> filter-->Vacuum Breaker-->Valve fully open-> vacuum pump
You might want to monitor the vacuum upstream of the filter as an indicator of the particulate resistance at the filter.
