Help with gradings in Land Development!!!!!!
Hi, I need to know how to do a grading in a terrain digital model with a 0.50m increment. I want to know if it is possible to put a first level and increase the next parcel 0.50m up from the first one.
RE: Help with gradings in Land Development!!!!!!
What are your intentions (e.g., Are you going to calculated the volume of that one parcel ? Are you trying to get design contours? Are you trying to compare two different volumes? I can probably answer your question if you will be more specific. What's your intensions and do you have any
existing terrain data?
Brian
