creating geometry usable for machining
I have a round core with ribs on the sides and I need to create some 2D geometry in 3D space (2 profiles @ different heights) in order to wire edm these ribs. How can I create these profiles and save them as a DXF or DWG. Maybe I can't in SW, I'm still learning. I tried creating split lines from intersecting planes to the body and I can get that but I'm not sure if I can pull that geometry and use it as 2D geometry.
RE: creating geometry usable for machining
use the Intersection Curve tool, instead of Split Line. It creates a sketch profile rather than splitting the models faces.
You can then make a config of the part so that the core body can be deleted. You should then be able to Save as to your choice.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Ooops ... sorry, missed a step. The last sentence should have read:-
"You can then create a drawing & should be able to Save as to your choice."
Also, you could 'copy-n-paste' directly from the profile sketch to an Empty View on a drawing, then "save as".
cheers
I need the 2 profiles at different elevations in space though. Do you see a way possible to do this. thanks.
What EDM software is it? Can it accept solid geometry formats?
cheers
I can bring solidworks files right into it but for machining it still needs 2d data. This is for a wire edm and it needs a profile for the top guide to follow and a profile for the bottom guide to follow. The geometry is skewed at 2° so I need to pull sections at 2 different levels and use those sections as my profiles to follow. I currently resort back to KeyCreator to accomplish this but am looking to have SW as my source for all my engineering situations. Maybe a parametric modeler has it's limitations in this area. I can import the SW file creating a wireframe on import the only thing I need to do is delete a bunch of geoetry I don't need. just seems redundant.
I'm confused!  You are EDM'ing a hole (the 'mating' shape of the core) into a plate of material, correct?
If you create a solid of the plate c/w hole & if the EDM software can read a SW file, what geometry do you need to delete?
cheers
let me get a picture posted and this should help explain it
Under the options tab in IGES export you can: export sketch entities. When I bring models into Delcam I will often use this tool to export my model along with all the useful sketches I create for boundaries, patterns and profiles...which I then create in the CAM package. I would try the IGES importer in your CAM package on your model after exporting it from SW *carefully review and test all you export options in SW*.
Follow CorBlimey's tips to make the sketches.
This should work. You can also just export sketch entities in IGES format as well.
What I don't understand is that your CAM package doesn't have the ability to create 2d features from 3d data. This seems kind of silly.
RFUS
The wire software is Esprit, and it requires that you create wireframe geometry in order to create features from. If someone knows different then i'm willing to listen.
OK, I misinterpreted. You need to cut the actual part ... not it's mate. After re-reading your OP I see I missed that.
However, I still don't understand what geometry you need to remove. If you model the part between the 2 planes you want to use and export that to the EDM machine ... why can't the EDM software machine it?
cheers
Quote (Esprit):
ESPRIT     Partners and Solutions
CAD Partners & Solutions
ESPRIT's data exchange functionality will read data from most native formats,including Autodesk, Catia, SolidWorks, Solid Edge, ACIS, Pro/ENGINEER and Unigraphics.DP Technology provides complimentary add-ins for several CAD programs that allow more seamless integration of the part models,saving the user valuable time.
cheers
I guess if I just cut the part at the two levels I need I could use the top and bottom geometry. Is that what your suggesting? I was thinking importing the complete geometry and create wireframe on import which would throw geometry up and down every one of them slots. That would be the geometry I would need to delete because it would try to select all of that on chain selection. All I need is the top profile, bottom profile, and one connecting leg between them.
Solidworks 2004. it's a little dated and this is a brand new machine.
