High pressure pump drilling application
For a drilling application I am in need for a pump that can handle the following:
- 250 bar discharge
- 50 - 100 L/min
- Fluid: water and/or bentonite or cement
I have been looking around on the internet but I cannot figure out what would be the ideal type of pump: Piston?
- 250 bar discharge
- 50 - 100 L/min
RE: High pressure pump drilling application
ht
or Geho
Vhttp://w
Both companies supply mud drilling pumps.
Naresuan University
Phitsanulok
Thailand
www.drilleronline.com
There is also pumps by Gaso and Wheatley but I do not have a website.
Are you sure about your numbers? ""
Are you sure :0
250 bar = 3626 PSI
100 l/m = 22 IGPM or 26.4 USGPM
Naresuan University
Phitsanulok
Thailand
As mentioned above, Gardner-Denver does offer mud pumps, but they typically supply much larger pumps than this applciation requires and suspect you might end up paying a premium or getting more pump than you really need. You might try Weatherford out of Houston.
If you're in europe my company can help
Good Luck
