Global Variables in a "matlab embeded function"
Hello...
I working with a Matlab Embeded Function and I need to export the values of the variable "A" to the Workspace DURING the simulation.
I tried using a "TO WORKSPACE" block, but the results of the "A" are are sent to the workspace only at the end of the simulation. What I need is sone function that'll send the results DURING the simulation. After a time step is calculated the results should be exported. That means that "A" should be exportet permanently as a scalar and rewriten in every step. The problem is that the embeded matlab function does not support Global Variables.
The reason for this is that in this embeded Matlab function (function 1) I calculate a value which I need to send to another function 2. That means, function 1 exports the value for "A" at time=t. In the next step the function 2 takes the value and send a signal to a valve (open/close).
A way to save "A" as a Global variable would be perfect.
Thank you in advance
claudio
claudio
