Control of pumps in a closed potable water distribution network
Hi all,
I'm currently working in a closed system of potable water distribution system, pumping directly to consumers, there are no storage tanks that I can use to shut off the pumps when it gets filled, so what is the most common way of controlling the pumps in this case ?
1- Pressure sensors at the furthest hydraulic point in the system ( or even several pressure sensors in several locations ) these will have several set point keep tracking the pressure from a minimum of 2bar to a maximum of 4.0bar.
2- A pressurized tank at the pumping station, is this the same as the hydropnumatic tank ? what is the difference between this and the surge vessels ? will this hydropnumatic tank work for surge protection ? what should it be sized for if it will work for both ?
The pumps will be VFDs. 2 duty and one standby. Pumping 180l/s at peak. 90l/s on average.
Your help is very appreciated.
RE: Control of pumps in a closed potable water distribution network
As for the pressure, although you do need to control the pressure at a MINIMUM at at the furthest point, the pump control is usually done locally. This is primarily due to safety - so if a valve somewhere is shut off the pumps will not overpressurize the entire system.
I would add that you should do a surge analysis to check for possible water hammer. You should also design the system with a surge relief valve to prevent over pressurization.
I would use vfd's to control the pumps from a transducer located in the pumphouse.
you said system pressure : how do you measure that and where do you measure it and how do you send the signal to your pumps ?
*thewellguy,
"I would use vfd's to control the pumps from a transducer located in the pumphouse"
Can you please explain more, do mean pressure transducer in the discharge line ? I cannot use level transducer cause I have no gravity tanks, even If I do they wouldn't be located in the pumphouse.
the idea of measuring the pressure of the discharge line directly after the pumps seems interesting , I thought about it. would this work ? it is definitely cheaper and easier.
*Cvg,
thanks for your input, I'm now confident that the hydropnumatic tank is not an option since it has to be too big to serve this community.
unfortunately building a gravity tank is not an option.
Guys,
I just need someone to confirm that using pressure sensors in several hydraulic critical points "these could be 2km away from the pumping station" would be a reasonable solution to control the VFD pumps. Please note that these pressure transmitter will be placed on the distribution mains.
Regards.
To answer you other question, yes it is very common in this area to control systems like this.
I’m new in the water distribution network design. There is a senior guy in the office who is convinced that controlling the pumps near consumers “2km away” would give the best indication of system pressure.
I checked the model for severe changes in demand to see how would that affect pressures in the system as overall , I noticed that when pressure was reduced by 50% at 2km away from pumps the discharge pressure just after the pumps was reduced by only 17%. The main reason for this big difference is because there is a relatively larger main feeding the smaller branches where the demand change was assumed to occur. I’ve assumed fixed speed pumps in this scenario to see the direct impact of a huge demand change.
The 50% reduction in pressure was due to a modeled fire incident.
It seems that there is some sense in what my senior guy is saying. Even though the 17% still give enough flexibility to detect the change but smaller demand changes could have much smaller impact at the pump discharge.
