Cutter Compensation UG NX
How to use function cutter compensation and to see in display correctly tool path ?
If I change TANTO to ON  then programm generates me correctly NC but my mill on display goes me on the center edge and workpeace cuts. NC code is correctly but for UG display it is wrong.
If  I  put TANTO   this is well  only for  display but programm add and beyond just  G41 or G42 and does not generate on contour points correctly.
Please !!!!!!
