open in excel as space separated file
hello
i am stuck on an excel issue when opening space separated text files.
i have many text files that i need to open in excel as space separated files..... i manually click thru the OPEN> etc etc etc tabs to do this.
can the excel defaults be changed to automatically be set to open all *.* files as space separated files?
thanks for any guidance.
daveleo
daveleo
RE: open in excel as space separated file
Sean
are you sure about that URL ??
daveleo
Several years ago I switched from the spreadsheet assistant to ASAP utilities and never regretted it.
Cheers,
Joerd
Looks like a simple typo by sean01.
Try this url for spreadsheet assistant:
http://www.add-ins.com/
daveleo
If you import a text file, the settings will stay the same for your session. So next time you do the import, you can click Finish right away - until the next day.
Cheers,
Joerd
that work just fine
thanks.
daveleo
