column splice with moment + 90 degrees orientation
I have column splice between two columns orientated at 90 degrees to one another (strong axis to weak axis). I also have a moment of 150 ft-kips.
Does anyone know of a reference that has a good example of this.
Thanks in advanse
T
Thanks in advanse
T
RE: column splice with moment + 90 degrees orientation
I can asure you I dont WANT to do this , but I have an existing column at the top of a building, and I am adding a few floors to the building. The new building will have moment frames which is why I a orientating the new columns above.
The fea sounds like a good way to go.
T
THe moment transfered into the existing column below will not be accidental, and I will definitly have to reinforce it on the weak axis side.
T
