pump discharge
pump discharge
Hello all,
I am analyzing a pump discharge line. After a distance the line goes under ground.
How can I model this below ground portion of pipe with Caesar.
Should I treat the soil as a restraint.
Thanks in advance
Thanks in advance
RE: pump discharge
RE: pump discharge
is easy... use soil modeller and create soil model by entering soil data.... next aplly soil model to the nodes which are buried..
is all
